4.4ghz tatsted nice
Permabanned
14 Jul 2005
Portishead, Bristol
Okay been back at stock for past few weeks and got some new ram today
I booted in at 4.2ghz asap
Went for 275mhz fsb what the ram is rated for at 3-4-4-8 @ 2.85v max in bios (need volt meater to adjsut my ram to 3v+)
Vcore was 1.5750v, AGP (chipset) was 1.70v.
She booted to bios, for a mear second, then she died.
Wouldn't boot anymore...set back to 4.2ghz and all is okay
So close for a P4e on water eh and my temps where reading 28c (i got a modded cpu, prob on the die)
It won't go there now!!!
I want 4.4ghz 24/7, can't go 4.3 even...4.2 seams my macx now!!
Good work man, but why was your AGP at 1.7Volts? from my understanding, changing that never benefits overclocks in any way. :confused: All it does it put more heat through your graphics card and end up shortening its life.
fatty1 said:
Nice 1 Drazic bring it over we will whip it under the cascade for some 5jig action :)
heheheh i so want to dude -80c odd i think 5 is easy mate
sargatanas said:
Good work man, but why was your AGP at 1.7Volts? from my understanding, changing that never benefits overclocks in any way. All it does it put more heat through your graphics card and end up shortening its life.
Uping the AGP Vcore helps het the NB (chipset) stable and allows for more overclocking...OCZ told me it and i found it works
Hmm, i didnt know that, i was told by several people it did nothing. I've never used that before, might check it to see if i can get 4Ghz.
There is a mod you can solder on the Abit IC7-MAX3 to do the shipset one, not too sure about the Asus but OCZ said to up the AGP volts...seams to work. The AGP volt is only the surplie voltage...i havent seen any temps go up at all
