- 22 Feb 2006
- Belfast
Hey 8 Pack
I wonder can you help me help me achieve 4.8ghz or 5ghz with my ivybridge??
max i can get (stable is 4.6ghz)
using: antec kuhler 920
temps under load around 65 degrees
help me 8 pack ! lol
pm please
other info:
4.6ghz
ai overclock tuner xmp
bclk 100
asus multicore enabled
turbo ratio manual
ratio synced at 46
cpu pll overvoltage auto
internal pll overvoltage auto
memory frequency ddr3 1600mhz
cpu voltage offset mode + 0.035
dram 1.5
cpu pll voltage 1.63750
cpu load line calbration ultra high
cpu power phase control extreme
cpu current capability 140%
Hyper Threading enabled
stable at 4.6.
your help appreciated master jedi :0)
p.s..... my temps suggest I can afford a little more of an overclock as i am only getting around 65 degrees under load. what do you think?
pm please
other info:
4.6ghz
bclk 100
turbo ratio manual
ratio synced at 46
dram 1.5
stable at 4.6.
