Hello geniuses, I want your expertise. This is my first build using cheap parts and the performance & quantity of stock fans are shocking - why do they bother including them?
I'm looking for full set of case fans for the H510 Flow, my GPU is currently thermally throttling with the stock two case "fans". I'm aiming to overclock.
What would you recommend? I've seen the suggestions for the Silent Wings Pro 4, P14's and so on, but my case allows for either two 120mm or two 140mm case fans at the front, and either a 120mm or 140mm fan at the top. The rear exhaust fan must be a 120mm one (I think). Here's the manufacturer's product page.
I like the idea of my fans being future proof for when I finally get that much needed pay rise and buy myself a AMD 9995xtxtx GPU in 2027.
I'm not interested in lighting, but I don't object to it either. I'll take it as a bonus.
Some specs you might find handy:
GPU: MSI 6700xt Mech 2x 12GB OC
CPU: AMD 5600x
CPU Cooler: Arctic Freezer 34 eSports Duo
Motherboard: Asus PRIME A520M-A II
Case: NZXT H510 Flow
Power supply: Corsair 650w uhhh... I forgot the rest.
Love you all so dearly,
P3.
CPU: AMD 5600x
P3.
