I'd like to connect 3 24" monitors and my 42" tv to my 6990 but I can't seem to do it. I'm assuming it's to do with the adapters. 3 in any comination is fine, but when I add a fourth my tv goes crazy and windows spams the "hardware detected" followed by "hardware removed" noise over and over until the tv turns off.
I have:
Monitor 1: Direct DVI input
Monitor 2: DisplayPort -> Passive DVI
Monitor 3: DisplayPort -> Active DVI
Television: DisplayPort -> HDMI
The tv cable is actually HDMI on one end and DVI on the other, so I'm using a DVI->HDMI adapter to plug it into the DisplayPort->HDMI adapter.
How can I get all 4 working at the same time? My roommate also has a 6990 and 3 monitors and is using the same connections as my monitors listed above(excluding tv). Is there any way I could use one of his adapters to make mine work and he uses his HDMI adapter or something?
I have:
