4 pin molex
17 Mar 2003
London
Can this Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN) be used to power my old IDE HD, DVD player and CD player which use the normal (old?) 4 pin molex power connectors?
The only info I can get on it is from this review (http://www.legitreviews.com/article/217/4/) which says it has 4 SATA Connectors support Serial ATA optical drives but no info on IDE drives...
Help!
It has according to this review
12" cable for main 20+4-pin ATX connector
13" auxiliary 12V connector for the CPU
13" cable with a 6-pin PCI-e connector
24" cable with three 4-pin IDE drive connectors
24" cable with two 4-pin IDE drive connectors and one floppy drive power connector
2 x 19" cables with two SATA drive connectors each
21" fan RPM monitor cable
Doh two seconds too late. :(
I wanted to place the order to be sure I have it tomorrow... anyway I just added a couple of Akasa Serial ATA PSU Converter (CB-052-GE) which are only a few quid extra, might come in handy for my next uppgrade in 6 months...
Thanks
