22 May 2010 at 17:16 #1 beefybarn beefybarn Soldato Joined 6 Jul 2008 Posts 4,963 Location Brighton Hi, does ocuk stock a cable to extend the 4pin motherboard cable as i could not find anywhere, cheers.
22 May 2010 at 17:25 #2 iNPUt iNPUt Associate Joined 9 Jun 2009 Posts 1,815 Location London http://www.overclockers.co.uk/showproduct.php?prodid=CB-022-AK&groupid=701&catid=48&subcat=153
22 May 2010 at 17:33 #3 beefybarn beefybarn Soldato OP Joined 6 Jul 2008 Posts 4,963 Location Brighton Thats 8 pin, i need the older 4 pin one.
22 May 2010 at 18:00 #4 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare it splits at the end, look at the pic
22 May 2010 at 18:04 #5 iNPUt iNPUt Associate Joined 9 Jun 2009 Posts 1,815 Location London Has your psu got an 8 pin, still think you can use that if you got a 4pin not sure how tho..
22 May 2010 at 21:39 #6 SupermotoMX SupermotoMX Associate Joined 22 Feb 2010 Posts 1,088 just plug it in one side fo the 8pin
22 May 2010 at 21:40 #7 Sparx Sparx Soldato Joined 30 Jul 2007 Posts 5,269 Location Lincolnshire stulid said: it splits at the end, look at the pic Click to expand... SupermotoMX said: just plug it in one side fo the 8pin Click to expand... ^ This..
