4-pin resistor cable
31 Dec 2006
Has anyone found one of these in the UK? I found some on the rainforest but all seem to be coming from Hong Kong. Any UK sellers? Loads of 3-pins, but I need for 4-pin fan.
Basically this...
No but if you did buy those in the image they'd need a slight modification to actually fit a 4 pin fan. A knife cut down between the yellow and green on the pin side to remove a sliver of plastic.
