40/43" Tv Recommendations
30 May 2004
Uk
Hi
Looking for recommendations for a Tv for my bedroom. Primary use will be my PS4 but will also be used for Netflix, DVD's etc. Don't really have set budget so will consider all options
Cheers
Best 43" set is the Samsung Q60 as they only brought out qled tech at that size last year. Cheapest set with a good picture will be a Hisense B7***, Im pretty sure the Q60R has game mode for low input lag and the screen quality will be decent but unsure about the rest.
Price difference between both is around £200
Cheers
I had looked at the Samsung Q60 and seems good. Just saw the Panasonic TX-40GX820B as well. Any reason to go for that over the Samsung? I know nothing about Tv's
Had a little look and that Panasonic looks great tbh, they are pretty much the same TV. Panasonic has a VA panel which has better blacks but not so good of a viewing angle and the Samsung can come with either and IPS or VA panel (random), IPS will have better viewing angles but not as good blacks.
Samsung TVs will have the added bonus of doing BT sports and Apple TV. Really depends how much money you want to Chuck at it.
