Can anyone recommend a TV that fits the bill? Finding the right one is an absolute nightmare with so many conflicting recommendations in what I read on sites like avforums
The LG 42LE8900 seems like the perfect fit, but I have heard the screen is very reflective and I can’t find anywhere in London to view it myself to make sure.
Why is the choice for plasma (G20/V20) so clear cut yet for LCD/LED there isn't an obvious choice?
- 40-50”
- Up to ~£1300
- Deep even blacks which means local dimming, or if this isn’t possible then without the common problems of edge-lit screens
- Decent viewing angles, preferably an IPS screen
- Matte finish, as I hate glossy reflective screens
- VGA input or able to turn off the image processing on a HDMI port so I can use it as a monitor
- Low input lag
- THX certified? Is this important?
