40" plus display on Trinity?
Yes 1920 x 1080P is no problem for an A10 5800K, its also good for a media center PC as it has a good IGPU in it.
The size of the display in inches does not matter. You could have a 40" with a resolution of 800x600, and a 5" display with a resolution of 1920x1080, the 5" display will be the harder one to run.
Now if you had a 40" Display and a 5" display both at 1920x1080 which would be harder to run? neither, they both output the exact same amount of pixels. Just the size of the pixels on the 40" are bigger.
