£400 Build - Can it be done?
Permabanned
19 Nov 2011
So, having finally decided what I wanted PC wise, I'm getting all my mates sorted so we can all play some games together. This particular friend's laptop recently died (got crushed!) and instead of replacing it with another £400 piece of tat, he was wondering if he could get a small desktop instead.
Now, its not much of a budget and this fellow has recently got a taste for playing PC games (finally!). He won't get much for £400, but £400 on a desktop > £400 on a laptop! He won't need an OS, DVD drive or a monitor. Can't go over £400 as I need to throw in a screen as well (he can have my old one for £50 or so).
I've thrown the 20th unlocked K CPU in there as I can sell him that as well for £30. Best I've managed to do knowing this is £10 over... then the screen. So £60 over.
YOUR BASKET
1 x Powercolor Radeon R9 270 TurboDUO 2048MB GDDR5 PCI-Express Graphics Card £109.99
1 x Gigabyte Z97N-WIFI Intel Z97 (Socket 1150) DDR3 Mini ITX Motherboard £93.95
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01) £59.99
1 x Crucial MX100 128GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT128MX100SSD1) £54.98
1 x Intel Pentium K Anniversary G3258 Socket LGA1150 Processor - Retail £49.99
1 x Raijintek Metis*- Black Mini ITX Case £35.99
1 x SuperFlower Amazon 300W "80 Plus Bronze" Power Supply £31.99
Total : £446.48 (includes shipping : £8.00).
Not sure on AMD side of things. As I said, would be great if it could at least do medium at 1080 on a few games.
Cheers,
Grady
AMD AM3+ dont have any good small boards and zero itx ones, so skip that.
There are AMD APUs and mATX boards, but if you add a gfx card to this to enable it to play games well, then that defeats the point of buying an APU i think.
Does it have to be that small?
Doesn't have to be that small, but smaller the better. I just liked the look of the case is all. Bigger just means I have to carry it up the 3 flights of stairs to his flat.... >_>
if it gets it in budget, then sure can go bigger!
Ah nice, probs best to go for a HDD due to budget. Why the 550w over the 300w? Or will it need it?
Would anything other than a Z97 be able to overclock the K?
yeah. at least get some "medium" quality 400-500w... ;) 300w not nuff. It also doenst mean it will consume the whole 500w, just the Watts ur system is using
my 2p:
YOUR BASKET
1 x Intel Core i3-4130 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £89.99
1 x Seagate SSHD ST500LM000 500GB 2.5" SATA 6Gb/s 64MB Cache - OEM £49.99
1 x Asus H81M-K Intel H81 (Socket 1150) DDR3 Micro ATX Motherboard £37.99
1 x Corsair Builder Series CX 430W V2 '80 Plus Bronze' Power Supply (CP-9020046-UK) £34.99
2 x TeamGroup Elite 4GB (1x4GB) DDR3 PC3-10666C9 1333MHz Single Channel Module (TED34GM1333C901) £26.99 (£53.98)
1 x Zalman T3 Micro -ATX Case USB 3.0 - Black £20.99
Total : £407.52 (includes shipping : £8.00).
hybrid sshd for the best of both worlds - large capacity of a hdd and snappiness of a ssd
i think you should forgo the oc-ing bit, if you're building for your friend, just saves the hassle tbh. the i3 non-oc is just as good/slightly better than an oc-ed pentium AE (especially with games that can take advantage of hyperthreading)
Can't improve on Stulid's build tbh. Clock that CPU to 4GHz, +100mhz to the 270 and the system will be pretty pretty darn good for £400.
BF4 on high settings 1080p @ ~50-60fps should be achievable.
It is the best card, but keep an eye on the Bgrade section as a few days ago there was a Gigabyte windforce 7950 for a £100'ish.
I like the i3 option tamzzy went for personally, given the difference in mobo prices you're looking at about £10 more for the i3 over the Pentium K and the i3 is well worth that in my eyes.
I only like pentiums as cheap chips - which when spending more on the mobo stops making sense to me. That's why I don't like the K edition personally.
