£400 ish machine
18 Oct 2002
Maidenhead
Hi all,
Can anyone recommend the following for around £400-£450.
Case
PSU
CPU
Motherboard
Ram
They will be putting their current pci-e graphics card in to it.
Also a 1tb hard drive on top (not in final price).
Thanks in advance
AMD Phenom II X4 Quad Core 955 Black Edition 3.20GHz (Socket AM3) - Retail £128.99 (£109.78)
OCZ Reaper 4GB (2x2GB) DDR3 12800C6 (1600MHz) Dual-Channel (OCZ3RPR1600C6LV4GK) £99.99 (£85.10)
Gigabyte GA-870A-UD3 AMD 870 (Socket AM3) DDR3 Motherboard £84.99 (£72.33)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £57.99 (£49.35)
OCZ ModXStream Pro 600w Silent SLI Certified Modular Power Supply £55.99 (£47.65)
Xigmatek Asgard Midi Tower Case - Black £26.99 (£22.97)
Total : £454.94
This is first effort, but you havent stated their current PCI-E gfx card, however this PSU should suffice anyway, or their intended use, but for that budget this is best all round really
and this addition drive- http://www.overclockers.co.uk/showproduct.php?prodid=HD-211-SE&groupid=701&catid=14&subcat=1279
Thanks guys. He currently has an ATI HD 4870, and has said he will be going to an ATI HD 5970.
the psu may still just about cope with a 5970
This is the spec he has been suggested. How does it compare to the ones suggested here?
Case: Coolermaster HAF 922 - £84.99 inc vat
PSU: Coolermaster GX650W - £65.99 inc vat
CPU: AMD Phenom II X2 555 Black edition retail - £83.99 inc vat
MB: Asus M4A89GTD Pro - £119.99 inc vat
RAM: Patriot G series 4gb DDR3 1333mhz - £89.99 inc vat
Total: £444.95
its a crossfire motherboard for a single card setup? even a 5970 is technically a single card.
and the cpu is a dual core.
PSU, i have seen only one review of it, and its got some issues(voltage levels and ripples)
Total: £444.95
builds suggested above are better than that quoted
