4000+ SD Max Safe Temp?
21 Jun 2004
Berkshire
Whats the max safe temp on a 4000+ SD? Im currently not going above 52 full load, is 55c still an ok max temp? (Want to overclock it more :p)
i believe they are fine up to 60oC but i really would try to keep below 55.
What are you using to measure your temps? I have found a big difference from the temps reported by the motherboard/bios and Core Temp. Core temp reports a 10C higher temp, (is this normal?) I have a 4000+ as well.
