4070-gaming ?
16 Aug 2009
Hello I don't want Windows 11 Silly question but my copy of windows 10 will be fine with these parts in the system. Also I can't find any usb slots ?
Code:
https://www.overclockers.co.uk/ocuk-gaming-gallium-amd-ryzen-5-5600x-nvidia-rtx-4070-gaming-pc-fs-1ej-og.html
Code:
You can deselect W11 from the drop down menu. The usb ports would mostly be on the rear of the motherboard, and you will also get them on the case itself. The G360A has 2 x usb ports on the top.
That system is a bit expensive though for what you are getting. You not able to build it yourself ? I would expect at least a 7600X cpu with 32GB DDR5 and more storage for that price.
I've Got long covid and find simple tasks hard I would want the pc for gaming
