4090 Power limit vs undervolt?
14 Jul 2017
Hello
i've seen different videos about it. some advice to undervolt, other to limit power slider.
i've limited the power slider to 80% without any FPS loss but that does not help another issue : coil whine.
Does undervolting works fine on 4090 and will limitt watts as well?
Thanks
Undervolting will decrease power draw.
I've personally got my power limit set to 70% as per Der8auer's recommendation.
Definitely the way to go imo. No point wasting power especially in this climate.
does limiting the power also limit voltage actually? My card doesn't draw more than 380w at 80% but the coil whine is still there
Oddly enough I'm finding that from a 'tweakers' point of view the 4090 has been the most boring card in a few generations :D
Don't get me wrong I think my 4090FE is fantastic, but tweaking the power limit, clock speeds, etc doesn't seem to be as good as the stock settings. Nvidia just seem have got it right, straight out of the box (for me anyway).
Pre tweaked by an algorithm for your convenience, seems CPUs are the same these days
And there’s me sliding it all the way to 133%!
did it melt yet?
