40D Leak (No images or spec)
5 Nov 2004
http://forums.dpreview.com/forums/read.asp?forum=1019&message=21756727
Just a matter of time now fellows..
attachment.php
\o/
Improved specs over the 30D will probably be
10mp
Digic III
Sensor cleaning
possible extra focus points and improved accuracy
Role on the 1Ds MKIII and 1D MKIII :)
SDK^ said:
\o/
10mp
Digic III
Sensor cleaning
I'm upgrade from the 20D to the 30D and as you know there wasn't a huge improvement so I expect I will end up upgrading again :D
SDK^ : New sig I see!
Thats a gorgeous bike SDK, my bro in law got a gorgeous one for xmas. Forget what it is, I will find out and post a pic later but that what you have is gorgeous. Im just in the process of building my Claud Bulter upto a better spec starting with brake disks! (amount of times Ive been caught out by rouge children on the streets! haha
It's not looking so good now though - 3 punctures in the rear tyre and covered in mud :/
Get some pics of your bike in that thread.
Anyway back to topic :)
At last 30D owners can shut up going on about the fact that it's only been 1 year since it's launch and won't be replaced for at least another 8 months. :rolleyes: :p
SDK^ said:
Lovely bike, i have a Hardrock Pro myself, i think yours a tad better though :p
One question, how is the bike being stood up in the first picture? Im saying to a friend it magic but he doesn't believe me!? :)
Thanks
Josh
Phnom_Penh said:
The usual trick is to stick a pint glass or something under the pedal. I wonder if he photoshopped it out.
Correct - Glass under rear pedal; cloned out :)
Phnom_Penh said:
but that's not your bike in your sig ;).
Yeah, an S-Works is about £2k over my budget :(
Great bike :)
I can't believe how many photog MB'rs there are.
Nor can I!
Appoligies for terrible pic! Its actually one of the first I took with my SLR, and the only one of my bike! Maybe tomorrow i'll try and get a snazzy one like yours!
I think its just the fact they had the 40d page up on the website, which probably means that they're planning to release details soon.
As far as I know there wasnt any other info on the canon 40d page.
Correct, basicly a place holder has gone up on the website. It has been rumoured that the a 30D upgrade (40D?) but people has started to suggest it wouldn't be released so soon after the 30D. This seems to suggest it will be.
