40GB PS3 connectivity...
Just wondering..
What is the effect on MP gaming on the wireless connection? I know when PC gaming using the actual Ethernet connection is a lot better to reduce lag, is it the same with the PS3??
Just wondering..
I doubt there is that much in it as long as you have a good strength/stable signal to your wireless router/computer. But I guess you will always get marginally better rates with a stable wired connection over wireless.
I use mine wired 1Gbit connection.
rp2000
I didn't actually know the 40gb had wireless, I've been switching wires about all this time lol.
Seriously it has wireless!?! I have been using an ethernet cable and never even thought to check if it had the wireless functionality.
I bought mine in December just before Christmas.
Will have to check that out once I get from work in Sheffield.
Just wondering..
On my PC it adds around 3ms latency to my connection.
