I'm fairly new to overclocking and I was having trouble overclocking my AMD a64 4200+x2 at all. I noticed that my pci exp clock were set at 100 mhz but the pci setting was at auto, the options are auto, to cpu and 33mhz. I have set it at 33mhz and this SEEMS to have made it better. I have also set the dram voltage at 2.7 as this was on auto before as well (my ram is guaranteed up to 3.0v, ocz ddr400 platinum). Is this the right thing to have done?
I have just increased the fsb to 220x11 for now but I have left the ram at 400 and HT at auto (making the HT link 1100 and the memory 220 ((ddr 440))). Am I right in thinking that if I want to go further I should turn the ram to 333 and the HT to 4x? Also at what point should I start to tweak the vcore, its on auto now 1.36.
My temps are within acceptable levels, not getting above 53,54 at load so hopefully might be able to get more out of it as I'm preety sure that the cpu is throttling my new 8800 gt.
specs:
A64 4200+, A8N e mb, 2 gb ddr 400, 8800 gt bfg oc.
specs:
(although im clocked a fair bit higher lol)
