I run a triple 1080p monitor array using NVIDIA surround, with each monitor set to 1920x1080@60Hz.
I am wanting to clone the middle monitor onto this TV, and put that on my wall to watch movies etc. It's my understanding that a DVI-D splitter and then a DVI to HDMI converter will do this. Sound is not an issue.
However.. In the specs, it shows the TV as having a 50Hz refresh rate.
Will this cause an issue? Will the TV be able to display 60Hz? Will this mess up my surround setup?
I literally just want to clone the middle monitors feed, that would be absolutely perfect.
Thanks!
Thanks!
