4400dualcore+7900gs from overclockers temp help
Permabanned
28 Aug 2006
Manchester-UK
hi all :)
finnaly got me gainward 7900gs from overclockers this morning WHAT A CARD
i also bought my cpu and motherboard plus this 7900gs from overclockers
im currently playing company of heroes (fantastic game best ive played in ages)
but when im running the game the cpu temp is like 53c dont know if its full load or not but i was only playing for like 25 mins and if i played it longer no doubt the tenmps would go up just wondering is this temop safe for my cpu is it overheating etc plus whats the recomended temp for it any advice welcome please as i dont wanna fry this baby took me ages to put together
thx :)
Hi,
Dont think you have much to worry about there with the temp. I know the CPU`s can got a lot hotter then that with out a problem. Also if it gets too hot they have a built in protection that will slow the CPU down so it does not damange itself.
You could always add more ventalation to the case but I think the temp is fine at 53
LoopyLee said:
Hi,
thx for that m8 cheers for helping :)
