£450 Build
27 Jul 2009
Hey guys my friend is wanting to buy a new computer. I told him its would be cheaper to build one.
his main use for it is gaming wants to runs games such as BF:BC2 on high settings or best as possible with his budget of £450
needs
vista or windows
mobo
gpu
cpu
psu
ram
case
thanks
I would contribute, but within seconds CAT will have something up that I cant disagree with.
InB4CAT: Dont get a HD5770 unless you're going to CF - which you wont be on that budget. Get a HD4870 or HD4890 instead
If you want a build which needs a copy of Windows 7 this is what I would get:
Phenom II X3 720BE ~ £100
http://www.overclockers.co.uk/showproduct.php?prodid=CP-238-AM
Asus M4A77D ~ £60
http://www.overclockers.co.uk/showproduct.php?prodid=MB-376-AS&groupid=701&catid=5&subcat=1482
4GB 1066MHZ DDR2 ~ £72
http://www.overclockers.co.uk/showproduct.php?prodid=MY-192-CS&groupid=701&catid=8&subcat=817
Corsair CX 400W ~ £37
http://www.overclockers.co.uk/showproduct.php?prodid=CA-017-CS
Coolermaster Elite 334 Midi Case ~ £28
http://www.overclockers.co.uk/showproduct.php?prodid=CA-184-CM
HD4770 512MB ~ £74
http://www.overclockers.co.uk/showproduct.php?prodid=GX-117-PC
Windows 7 Home Premium 64 bit ~ £76
http://www.overclockers.co.uk/showproduct.php?prodid=SW-127-MS
The total comes to around £447 excluding postage.
The game the OP mentioned will work better on triple and quad core processors.
