they are have a low power, which means they produce less heat and can be cooled passively...ideal for a htpc set-up when combined with a matx mobo utilising a amd780g chipset which can do onboard hd decoding.
platform wise intel/nvidia cant touch what amd have done with the combination of products.
for a htpc speed doesnt matter that much as long as you have enough speed to decode/capture/encode HD content. the radeon hd3200 on the 780g mobos takes quite a lot of decoding away from the cpu so you have enough left over to do other things at the same time if you wish with one of the low power 45w chips.
I have a 4850e and a 780G HTPC setup. 1 fan in the PSU and 2 in the case make the entire setup pretty much silent unless I get down on the floor and put my ear up to it.
Thrown every kind of HD content at it and it hasn't jittered once. It's pretty much the perfect HTPC combo that Intel can't touch right now.
You have got me thinking now, Im presently building an HTPC and was going to get an intel 21XX but after reading a review of the 780G chipset, this might be a better option. How much hotter does the chip run with just passive cooling and what cooler do you use?
