4600 X2 Temps
31 May 2005
Just installed my shiny new 4600 X2 and was wondering about the running temps. I have an akasa EVO120 cooler and at idle it runs around 35 and goes to 51 under load. However the fan spins up to maxium or very close. It idles at 1100rpm goes to 2000 under load to keep it at 52 ( I am using Q fan on asus mobo).
When putting on load the temps go up very fast, you can hear the fan spin up when you start doing something. The system goes from silent to fairly noisy. I have heard somewhere that this means there is a bad thermal conection between the cpu and heatsink, is this true ?
And are those running temps ok ?
Those readings seem fine, although it does take a while for the core to heat up, strange why it spins up suddenly under load.
