I've got Vcore set to 1.25V @ 4.5ghz and got it to downclock automatically with the power saving settings, however I want to get the voltage to drop when it downclocks.
I can get it to drop by setting it to auto, but it gives me about 1.4V, which obviously isn't good, but it does reduce the voltage. So I set to normal and give it an offset and this also allows the volts to drop, is this the only way to do it?
As I'm worried it will change the voltage without me knowing? Or can you limit a max voltage this way?
I'm using a G1.Sniper Z87
