Need some help, currently have my 4670K @4.4Ghz and in games it is rock solid, few hours of watch dogs, Dayz epoch/arma2/3 no problem maxing temps at 59c, as much prime95 as I am comfortable giving it which is around 2 hours and temps max out at 70 under water now my fan is turned up, still though I get intermittent restarts when doing menial tasks like opening a web page or YouTube videos that shouldn't be putting anything on the cpu really. This happens maybe 1 or 2 times a day when the system is under minimal to no load what so ever and the cpu is running at 800mhz!
Then I noticed looking through HWiNFO my idle vcore is fluctuating around 0.110v and 0.200v. I have watched it dip as low as 0.050v a couple of times and this has me thinking that this may be the culprit as that seems very very low even for a modern cpu?
I am at the moment running.
Multi x 44
Vcore offset + resulting in 1.320v
LLC 50%
uncore x 33
ring voltage 1.100v
vccin 1.900v
EiST enabled
C-states enabled ( have tried all of them and they just lower it over the average more than anything else)
And that is where I am now, stuck! I have no idea if this idle voltage is normal even as abnormal as it looks to me, I also have no idea how to raise it to make the system more stable at or leaving an idle state.
I would really appreciate any help you can offer, would be nice to know your idle voltages too please.
Multi x 44
LLC 50%
uncore x 33
ring voltage 1.100v
vccin 1.900v
EiST enabled
