Hi everybody,
got my system running woh!!! spent the whole of last night trying to fit the Thermalright Ultra-120 Extreme, my specs are. I am bit
concerned about my temperatures, i've only got one fan running at the moment, i might attach the nexus fans later on.
My cpu temp reading, this is direct copy from the PC Health Status menu in the CMOS.
Cpu temp; 45c/113f
System temp; 34c/93f
PWM temp; 51c/124f
CPU fan speed; 1155 RPM
system fan speed; 0 rpm
aux1 fan speed; 0 rpm
aux2 fan speed; 0 rpm
cpu core voltage; 1.17v
ddr2 voltage; 1.92v
cpu vtt voltage; 1.19v
mch 1.25v voltage; 1.25v
atx +12v; 11.89v
atx +3.3v; 3.26v
I've got a fan mate, i haven't attached that, the internal wiring is not so good. Just in case your ask i have the fan blowing into the ultra.
Cpu temp; 45c/113f
PWM temp; 51c/124f
ddr2 voltage; 1.92v
atx +12v; 11.89v
atx +3.3v; 3.26v
Samsung SpinPoint T 500GB SATA-II 16MB Cache - OEM (HD501LJ
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK)
Corsair 4GB DDR2 XMS2 PC2-6400C5 TwinX (2x2GB)
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - Retail
EVGA GeForce 8800 GTS "Crysis Edition" 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (512-P3-E841-AE-CrysisUK)
Thermalright Ultra-120 Extreme CPU Cooler (Socket AM2/LGA775)
Scythe S-FLEX 1200RPM Ultra Quiet 120mm Fan - 3/4 pin
Zalman Fan Mate 2 (x3)
Samsung SH-S203NRSMN 20x DVD±RW SATA Dual Layer Lightscribe ReWriter (Beige/Black/Silver) - Retail
Abit IP35 (Socket 775) PCI-Express DDR2 Motherboard
Arctic Silver 5 Thermal Compound (3.5g)
Antec Solo Quiet Mini Tower Case - No PSU
Samsung SpinPoint T 320GB SATA-II 16MB Cache - OEM (HD321KJ)
Logitech Cordless Desktop MX 3200 Laser - Retail
[I haven't opened this, so i might return it if the onboard sound is good enough] - Auzentech X-Plosion DTS Connect 7.1 Sound Card – Retail
