470 help required
27 Feb 2009
Hinckley
Anyone on here have a 470? If so what kind of temps has it been going up to during past few weeks of heat we've been getting?
Also, on auto does the fan always go up to 100% rpm?
Hi i had a 470
The 470 i had would idle around 45c and 80-95c load with fan set at 60%
My temps have only increased 3-5C
Very important that your case has good airflow that will improve you GPU temps.
Also the GTX 4 series do run hot but there not as bad as ppl/reviews claim imo.
If the fan is set on auto i found the fan settings were a little out a place and the fan increased at high temps, when it would have been better to to see the fan increase when temps were at 70c ish for example.
When gaming i just set my fan to 60% and temps were fine then hope this answer your question
