Hi 8 Pack,
I have been working on overclocking my 4770k (with Z87X-OC board) and now have it running at 4.5 GHz. I used RealBench for stability testing after every change I made in the bios, 5-6 runs of the stress test each time. I have also done some gaming and not had any problems (yet at least).
I am just wondering if you could advise me on what to change to reduce the temps, the settings I have changed to get 4.5 are:
Multi: 45x
Vcore: 1.3
VRIN: 1.8
RING V: 1.25
VRIN override LLC: Extreme
C1E, C3, C6/C7, and EIST: All Disabled
Max temps after 5 passes of RealBench were 87/86/83/76 although during gaming they haven't been quite that high (will test with BF3 multi tomorrow after work).
4.4 was stable with these settings (although I didn't try gaming):
Multi: 44x
Vcore: 1.24
VRIN: 1.7
RING V: 1.1
Max temps: 79/77/75/69. I will most likely drop it back to this if I can't get the temps down for 4.5
With everything at stock my Vcore was showing 1.1246 in Core Temp with turbo active at 3.9.
Also, is my RAM worth overclocking? I have this: https://www.overclockers.co.uk/showproduct.php?prodid=MY-158-GL
If it is, could you give me some advice on timings for higher speeds please?
Thanks.
Multi: 45x
Vcore: 1.3
VRIN: 1.8
RING V: 1.25
Multi: 44x
Vcore: 1.24
VRIN: 1.7
RING V: 1.1
.With everything at stock my Vcore was showing 1.1246 in Core Temp with turbo active at 3.9.
Thanks.
