4770k overclock
26 Aug 2013
Hi all I've just purchased a maximus hero mobo and 4770k. I'm wanting to over clock but the more I read the more complicated it gets!
So tell me if this is right
My goal is 4.5ghz
From what I've read all I have to do is bump my CPU to 4ghz. And work my way up from there until I BSOD.
If it crashes and I haven't reached 4.5ghz yet bump the voltage up bit by bit until no crashes happen.
Then turn off all power saving options on mobo?
Then if all seems well just run a stress test over night and make sure my temps haven't exceeded 85degrees.
Please add anything else I need to do or shouldn't do!
Thanks in advance for any help/advice
Dave.
Hopefully you have a decent cooler with that setup, haswell chips heat up fast as you push up the voltage!
Make sure to set the loadline calibration to high/extreme so when under load the cpu core voltage doesn't pull back a bit causing it to become unstable.
Whilst every chip is different, from my experience the i7-4770k should be able to boot at 4.5ghz with a vcore of about 1.25-1.3V to give you a general region, although your chip may need more or less.
