Just checking my temps are ok on new build as was worried at first & was going to reseat my heatsink...(temps shoot up right away in core temp when running prime.)
Quick list..
mobo Asus z87-pro
cpu 4770k not manually oc'd.
heatsink Noctua NH-D14 (PWM fans)
Idle temps are around 30 degrees..
Fired up core Temp & set prime95 at small fft's & ran for 20 mins..temps shot up quite quickly to nearing the eighties..which was got me worried..then remembered I'd set a bios setting (system performance) from normal to Asus optimal. (it increased wattage shown in core temp & mhz over 4000..ie..ran the cpu faster...but a lot of you will know that already
So changed the setting to normal & wattage dropped/mhz went down to below 4000
Ran prime again at small fft's for 20 mins & temps hovered between 60/63 degrees...sigh of relief..
So...are the temps acceptable for either/both settings?? Obviously some kind of oc might have kicked in at the optimal setting...& being a gamer....& given the higher temps of optimal setting..(& I know prime punishes more than games)..Any opinions of if I should stick the system performance setting on normal or optimal?? (Not sure if the higher MHz/wattage on optimal setting only kick in when needed)
While I'm at it...there's a setting for cpu core ratio...currently set at default of per core....should I leave it at this or set it to auto or synch all cores??
Any feedback appreciated as always. TIA..Andy.
Quick list..
mobo Asus z87-pro
)So changed the setting to normal & wattage dropped/mhz went down to below 4000
but nothing more than that.
