4770k at stock
Corsaire H80 cooler
gigabyte gaming 5 motherboard
Case Phantek enthoo pro midi
Idle temps 23-27c
after 10/15 mins of prime95 (blend test) temps are between 76-80c
H80 is on the 3 profile connected to the CPU_OPT header (says water cooling in the manual)
Phantek hub is connected to the CPU fan header and a sata power connecter
gonna try switch the connections round later.
are the prime95 temps normal?
cheers
Corsaire H80 cooler
Idle temps 23-27c
cheers
