Processor: 4770k (delidded)
Cooler: Noctua NH-D14
Motherboard: Asus Z97-WS (Latest bios, 2304)
RAM: G.Skill F3-1866C8Q-32GTX (32GB, 4x 8GB DIMMs, 1866mhz, 8-9-9-24-2T)
GPU: Asus R9 290x
PSU: Corsair AX1200i
OS: Windows 8.1 64-Bit
I'm struggling to overclock my 4770k very far at all. In fact I think I've got somewhat of a bum chip as I'm having trouble stabilising:
4.3Ghz/3.5Ghz (Core/Uncore) at:
I run scientific simulations on my machine (which use AVX2) so I'm using the latest prime95 to check stability. Sometimes I'll get 4hrs into a run and then the machine will either BSOD with a 101 or 124, or the prime95 application will crash or error with a rounding error.
I achieved prime95 stability at 4.2Ghz/3.5Ghz using:
I guess my first question is whether I should be increasing SA and IO voltages for this memory configuration at all? And otherwise any additional changes you'd recommend trying.
Thanks in advance!
GPU: Asus R9 290x
Code:
Vcore: 1.3v
Vcache (Vring): 1.15v
Vin: 1.9v
VCCSA: +0.15v (~1.016v)
IO Analog: +0.15v
IO Digital: +0.15v
LLC: Level 9
Memory: Set using XMP (1866Mhz 8-9-9-24-2T)
Code:
Vcore: 1.29v
Vin: Auto (~1.74v)
VCCSA: Auto (~0.808v)
IO Analog: Auto
IO Digital: Auto
LLC: Level 9
Thanks in advance!
