Hi guys.
Just wondering if someone might be able to do a quick sanity check for me since I have been out of the loop for a while on CPUs and the like. After finally sorting out a replacement motherboard my new system is up and running. everything seems good and stable, but I was just wondering if someone could do a quick look at the display here and see if anything is obviously amiss. The only thing I have noticed is that the chip gets real hot in games (can get up to low 70s) but I understand this is pretty normal for Haswell and nothing to worry about. I am not interested in overclocking at all and would like to run at factory settings, which is why i was wondering if the ASUS AI suite was changing things. Should the cores not be running at a lower speed when not in use?
Thanks a lot, you guys are great!
Please use spoiler tags for images over 1280 pixels wide.
You can enable/disable it in the BIOs and I think it's called something like "speedstep". If thats enabled you could check the power plans on your Windows as if its in high performance mode the CPU wont clock down.
