1.35v is fine on DC chips for 24/7 use, due to improved power delivery compared to older hw chips. Real bench is a good test and more realistic than p95 etc. Temp wise as long as its not throttling when testing it will be fine. You won't see temps this high in normal use. My chip in sig maxes at 81c under real bench. 1.300v @4.7ghz, gaming it can be anything from 64-74c on the hottest core. Still well within safe limits. Theese are just hot running chips by design.
