Hello, just wondering what offset you guys are running at?
I just bumped my multi to 47 using normal voltage setting with no offset and when i got into windows the voltage was 1.45v
I was under the impression that Auto vcore setting adjusts the vcore to suit but on Normal vcore it stays at stock voltage, at least thats what it seemed to be on my last CPU. I guess im gonna need quite a big negative offset to get it back down to a reasonable voltage.
