Hi all, I have just upgraded from a 4670k to a 4790k as a present for my birthday from the wife. I had the original cpu running at 4200 ghz as I had no real need to go higher however I thought as I was upgrading the cpu I would try and sort the overclocking properly.
I am using a gryphon z87 asus board and I have it set at 4.4ghz and I am using adaptive voltage, the problem is in order for me to get the cpu to run at the desired voltage I also have to set a minus offset of 0.07v as otherwise cpuid reports 1.287v under full load.
The overclock seems very stable but I don't understand why when I put 1.2v in the additional voltage for overclock in the asus bios, it doesn't stick to this value without the offset.
With the offset cpuid reports about 1.21 ish.
Can anyone shed any light on this.
