Hi all,
Firstly - a little note, I am not too familiar with overclocking since Sandybridge - so there is every chance I've made an error somewhere along the line, hence why I'm posting here!
I recently discovered my 4.7 overclock was unstable (as in, rarely) - which made me revisit it and re-do everything from step 1.
Currently - I'm using the following settings 100% Stable:
Multiplier: 46
Voltage (note: I did this on "Manual" before switching to adaptive): 1.240
Eventual CPU Input: 1.700 (This could probably go lower).
AIDA64 / ITU run fine, temps reach around 65-67 deg max.
Cooling: Predator 240
Now, as far as I can tell, to get 4.7 - I require an input of around 1.9 (or more), and a core voltage of 1.32 or there abouts.
I'm never sure about the CPU input voltage tbh!
The problem with this, and my current overclock is I'm not sure on the safe voltages for a 4970k - and, I used to use Prime95 for stress testing.
Only, this is now very weird (and toasty).
For example, during 4.7 testing - Prime95 would start off a hit about 72-74 - and be fine. Although after a while, it'd suddenly shoot to dangerous highs of 90-100 (quickly abandoned the test as soon as this happened).
This happens on a "Blend" test everytime, no matter what voltages I'm using.
ITU / AIDA64 is always fine though....?
So yeh, a little confused about that, and also where to go with my 4.7 ambitions.
(Note: currently bios settings are: http://imgur.com/a/ABaaR )
Thanks for any advice
Multiplier: 46
