Evening all!
I've been playing around with my 4790k today. I've managed to ramp her up to 4.8GHz with the vcore manually set to 1.3v. I've run test after test and it's completely rock solid. Peak temperature under synthetic loads is 77c, but that was a one time high, it's normally around 73c. In games it hangs around the 60's.
Question is, is 4.8GHz a normal overclock for a 4790k, quite good, or a bit low?
I tried 4.9GHz and as soon as I fire up and stress on it I get a BSOD no matter what voltage I push through it. I'd kind of hoped for the legendary 5GHz, but alas no.
Specs
i7-4790k @ 4.8GHz
16GB Crucial DDR3 1600MHz
Gigabyte Z97P-D3 motherboard
Corsair H100i GTX 240mm AIO
Specs
i7-4790k @ 4.8GHz
