Hi,
I moved house today, so my pc was in the car for 3hrs, and carried around a bit.
Up to this point my pc hasn't been switched on for 1 month as it was stuck at my old house.
It used to get 1064 on xtu benchmark at stock with a max temp of 66deg.
Now I'm getting a max temp of 74deg and only 1060 marks in the bench.
Im using hyper 212 evo.
Do you think the cooler has moved or the paste has dried out?
What could be causing this issue?
Idle temps have also risen from 27deg to 31deg.
Runs mid 50s in games.
Also my processor seems to be running at max clock at boot, like 4.4 ghz. It then slowly calms down to 800mhz. I sweat it never did that before, is it normal? I swear before it ran at 800mhz from boot.
Thanks for the help!
It made way for a house purchase
