Hi folks - newly registered here but lurked for a long time
So I just got a new system put together, the main specs are:
i7 4790K
Asus Maximus VII Ranger Z97
16GB Team Xtreem LV DDR3
Geforce GTX 970
This replaces my old C2D system and so far I am loving it. Plays everything I throw at it in high or ultra settings and no stuttering or signs of lag.
However I have noticed that the CPU runs very hot, even when not heavily loaded.
For example, right now it is sitting about 45% load and temperatures across the 4 cores are averaging about 83C!
I am using the stock cooler (for the time being - until I get paid, then going to get something better) and I also have the clocks at stock, turbo mode etc has not been changed from the default.
Surely the stock cooler should be able to adequately cool the CPU when not overclocked, and not doing an awful lot of work?
I have checked that the cooler is properly installed, and have also run the board outside of the case to see if this was the issue. I am still getting the same results.
At loads of 55-60% and above the cpu is hitting 100c within seconds and starts to throttle down the speed.
Is this normal for these chips, or is the stock cooler really that bad?
Could the CPU be faulty?
I have heard the Haswell and DC parts run hot but didnt think they would heat up so much unless OC'd or doing a lot of work.
Any advice would me much appreciated!
i7 4790K
Geforce GTX 970
