Hi Guys,
I currently have a 4790k 4.4ghz and a 1080 ti.
Is it worth upgrade my cpu?
I only use my pc for gaming at 1440p and not sure if its worth the money to upgrade.
Ain't worth. It better option to delid the 4790K, overclock it another 10% and wait for next round of CPUs
I game at 1440p changed from a 4770k that ran at 4.6. It was well worth it for me . Tw2 went from 50-60 ish fps to 80+. Bf1 on a 64 man map went from 70-89 to a minimum of 105 fps. I found it well worth changing to the 8770k
Am lucky as it runs at 5.2 as well.
you must have upgraded or overclocked your GPU at the same time. BF1 uses 4 threads so the CPU upgrade wouldn't get you an extra 30FPS alone.
did you go from 8gb ddr3 to 16gb ddr4?
There may have been an update. In that case yes more cores more fun. Plus the faster ddr4
