Okay so recently built a system using a 4790K and a Noctua NH-U12S cooler.
I haven't overclocked yet per se, instead I've used Intel XTU to increase the Turbo frequencies so that all four cores can run flat out at 4.4Ghz and this works fine. Max temps I've gotten on the CPU is 75c during heat stress test.
So what about voltages? I have set 0 LLC in the BIOS but the voltage is dynamic. Highest I've seen reported is 1.22 and this goes much lower when the CPU is C-stepping down to lower frequencies.
Question - there seems to be a consensus that a fixed voltage is better? Is there any truth to this and what, if any benefit, am I going to see if I manage to set it up this way?
