I've recently build a 4790k system using a gigabyte z97m-d3h motherboard. I'm using the stock cooler at the moment with artic silver 5. Idle temperatures are usually in the low to mid 30s. I just encoded a video using handbrake and coretemp was showing the temperatures in the 90s, occasionally peaking at 99c. I'm not running any overclock. Is this something I should be concerned about? Should I consider a different cooler if I'm going to be doing the odd bit of video encoding?
Thanks
Thanks
