With just my desktop on I have got 48 Processes running. I have got AVG Antivirus and Zonealarm running (free versions) but should I have so many processes running? How do I know which ones I can turn off and how would I turn them off?
joroma said:I have Windows XP with sp2
No option to disable process when I go to priority?!
I just googled "that free program" but the results aren't too clear.rickyt said:48 is a little high [but nothing to worry about], but I've seen 78 on a PC .Mine is 38 at the mo . Try out that free program called what's running , it'll give you an idea of whats in the background and give you the chance to turn them off.
This? http://www.whatsrunning.net/whatsrunning/main.aspxrickyt said:No I mean something like What's Running , Ive just checked my download site and it's still there , so it's still in use and very good .Heres a brief summery :
What's Running is a product that gives you an inside look into your Windows 2000/XP/2003 system.
Explore processes, services, modules, IP-connections, drivers and much more through a simple to use application. Find out important information such as what modules are involved in a specific process.
Control your system by starting and stopping services and processes. Configure your startup programs easily.
I have it on a few PC's and I can confirm it's very good.
File size is 1.1mb
[if you get stuck I can always send you a copy )
No, he means thisjoroma said:I have Windows XP with sp2
No option to disable process when I go to priority?! By hijack this, do you mean post a thread?
