48” tv recommendations
18 Feb 2007
London
Hello :)
I’m trying to help my parents with a new tv, the max size is 48” for where it needs to go.
Although I’ve fitted an Apple tv4k for them they don’t use it much, that’s most likely because they use a virgin media TiVo box at the moment for recordings and such, but in the months ahead they will be getting rid of VM altogether, so won’t have a set top box.
For ease of use the new tv needs all the streaming apps like bbc iplayer, itv x, Netflix and such. Think this will be easier for them than having to keep grabbing the Apple remote to use the catch up apps.
Budget is about £1k
The LG C4 fits the bill perfectly I think, was looking at Philips as well but some of them don’t seem to support bbc iplayer!
Is there any others to consider perhaps from Samsung, my brother has a new Samsung tv which has the connection box you can tuck away somewhere, which is quite good.
Anymore choices would be welcome with Black Friday approaching so I can compare some prices at the time.
Edit/ Thoughts on the Samsung S90D as this is cheaper than the lg c4.
Thank you
