4800 X2's...
4400+ @ 2520 on air as per sig... my memory is ****(wont run over 210, 2.5-3-3-7), which is why i run on a .5 multipler using the /12 divider
No swearing, read the FAQ.
Otacon
My 4400+ is at 2.66GHz at present. Had it about 3 months now so it might be a crapper overclocker than newer ones. Still, I feel it might have some more headroom in it - might try for more tomorrow or over the weekend :)
My 4400 is at 270/10 1:1 so 2700 atm solid as a rock.
Will possibly go higher as i have worked my way up to there without a problem but its a complete new system so not too sure what my memory is going to do reliably (gskill HZ)
reading some reviews on the HZ they were stable at 275mhz and anything over that they got a bit flakey
