480mm Radiator
1 Mar 2015
West Sussex
Hello
This is my first post here. I've read lots here over the last few days, so thank you for all the information.
I am starting a Watercooled project using an Enthoo Primo and have been
inspired by a couple of builds here (Primo Midas and Enthoo Primo Watercooling Build).
I'm trying to find if OC sell a 480mm radiator that is less than 125 wide.
The EK 480XT would have fitted but isn't sold anymore.
Any ideas greatly appreciated.
Many thanks
C
Hello
Many thanks
C
Hi mate
first of all, welcome
and then the ax480 would fit as well (I've got it and have got an enthoo primo).
activate your trust (bottom right of your post) and send me a message and I'll happily help if need be
Hi Jim,
Thanks very much for the reply. I have activated my Trust.
Does the ax480 rad fit in the bottom of the Primo case? The spec. shows a width of 128mm (and the bottom of my Primo is only 125mm).
Thanks again.
C
Hi Jim,
Thanks again.
C
no worries!
ah no sorry I didn't realise that you meant for the bottom. it's too wide for there
I'm sending you an email now
