4850 multi-chanel audio
2 Jun 2006
Aylesbury, Bucks
Is there any trick to getting multichanel audio to work over HDMI with these cards. My colleague has the card connected via ati dongle to hdmi to his denon amp, but can only seem to detect stereo. Is there anything that you have to enable, or switch on to get this to work with 7.1? Any ideas would be gratefully received
Found it, thanks
(Make sure your amp is on and with the right input selected before you do any of this to ensure correct handshake when the PC boots)
Go to Realtek.com.tw
ftp://202.65.194.212/pc/audio/HDMI-R203.exe
Download the ATI HDMI Audio Driver from their HD Audio driver download page.
Install.
Switch to the new HDMI Audio Device (might be called ATI HDMI Audio) in playback, change the HDMI Audio to default.
Click Configure, then select the number of speakers you want to use; Quadrophonic or 5.1 in your case. Click ok and go through all the follow up tests.
Then click the ATI HDMI Audio in the list and click properties. Look through the tab til you can find the available signals and check all the ones your amp will support; DD and DTS being the usual ones, along with the correct Khz settings.
Click OK.
Restart to make sure any settings and handshaking issues are not involved.
You should now have PCM HDMI audio to your amp, and when there is direct DD available that will be sent over the HDMI providing you are in straight/direct mode on your amp
Please note if you are a purist for music playback that having output to 5.1 will enable a bass management function for WMP mp3 playback, rather than straight 2.0 giving you 2.1 output, temporarily changing this to only have 2 speakers with configure again will deal with this.
I tryed this but doesnt work.All it did it disabled the HDMI in soundmax and killed the picture on secondary screen.I hope there will be a lot of posts about tjis to solve this problem:)
