- 10 Dec 2007
OK, so I hadn't really played any games for a long time and my 4850 has sat effectively unused for a while, up until this weekend when I decide to install Mirror's Edge. I start to play, and after a couple of minutes in the game, the fan on my 4850 starts making a hell of a noise. I alt-tab back to the desktop and open up CCC - the card is at nearly 110°C and the fan is going crazy trying to stop it from melting. After testing out various different fan settings, the absolute lowest I can get the temperature under load is 105°C, and that's at stock clocks and with fan speed at 100% (which is so loud that it's almost defeaning).
When I first bought the card, idle temps were in line with what you'd expect, and I remember that after a few months they'd crept up quite a bit which concerned me, but summer had arrived at that point so I wrote it off to ambient temp increase - obviously I was wrong about that and the card itself was getting hotter over time. Today, the card idles at 80°C even with the fan speed manually increased to 45%.
I know the stock cooling on these cards is accepted to be poor, but does the fact that the temp started out perfectly normal, and has gradually crept upwards over the course of a year or so possibly indicate a problem with the card rather than the cooler? I know I need to replace something, but I would hate to spend money on aftermarket cooling for a broken card. Thanks in advance for any thoughts.
Bonus comedy picture of card idling at 80°C at stock with fan set to 45%
