4850's in crossfire
2 Jul 2007
Cheshire East
hi
anyone know why the 2 graphics cards are running at different speeds. I used the ATI overdrive to automatically set them in ccc ....or is this normal...maybe no 2 cards are identical...if your wondering why the other bits are on there....i was getting ready to post my overclocks on our clan forums when i noticed the difference :0
Set them both manually to the lowest card for crossfire...It's because one card is better (according to the ati test.which means little) so You chosen Automatic find max clocks for each card has done just that ;)
There's no need to set them both to the same speed, Crossfire handles different clocked cards just fine, unlike SLI.
